[Gdal-dev] bug: gdalwarp producing larger files than no compression at all
Matt Wilkie matt.wilkie at gov.yk.ca
Thu Feb 1 15:59:53 EST 2007
Dear GDAL,
gdalwarp (fwtools 1.1.4, win32) when using combinations of resampling,
pixel interleave and compression is producing files which are larger
than if no compression at all is used, up to twice as large.
    gdalwarp -co compress=lzw -co interleave=pixel -rb \
      source.tif gw_lzw-pix-rb.tif
    gdal_translate -co compress=none -co interleave=pixel  \
      gw_lzw-pix-rb.tif tr_no-comp_pix-int.tif
Result:
    328,390 source.tif
    524,786 gw_lzw-pix-rb.tif
    328,274 tr_no-comp_pix-int.tif
I files a bug with more info and data samples at
http://bugzilla.remotesensing.org/show_bug.cgi?id=1470
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
