[Gdal-dev] create buffer of a shapefile on the command-line using ogr - possible?
Wolfgang Qual Wolfgang.Qual at gmx.net
Tue Feb 6 03:18:34 EST 2007
Hi Frank,
ok. Thanks for your answer. Maybe it will be possible in the future... ;)
Wolfgang
-------- Original-Nachricht --------
Datum: Mon, 05 Feb 2007 10:09:41 -0500
Von: Frank Warmerdam <warmerdam at pobox.com>
An: wqual <wolfgang.qual at gmx.net>
CC: gdal-dev at lists.maptools.org
Betreff: Re: [Gdal-dev] create buffer of a shapefile on the command-line using ogr - possible?
> wqual wrote:
> > Hi list,
> > is it possible to create a buffer-theme (for an input shapefile) on the
> > command-line using ogr-utilities with some sql-commands? Or do I need to
> > write a script (I have read something about this in this list). I am
> just
> > curious...
> > Any hints would be great.
> Wolfgang,
> There is currently no way to invoke operators like buffer using the
> commandline
> tools.  You would need to either write a program, or a script in python,
> etc.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
