[Gdal-dev] gdaladdo with .rrd ignoring compress overviews?
Tue Feb 6 23:28:22 EST 2007
Matt Wilkie wrote:
> Hi gdal, I'm on roll today! Here's another one: Why does gdalinfo report
> that overviews are compressed with RLC when I asked for LZW? Can only
> one --config option be used at a time? Or does .rrd not support choice
> of compression?
Matt,
Erdas Imagine files don't support LZW.  RLC is the only supported
compression (I think).  Frankly, I don't know why it even used the
RLC compression.  I don't see any support for the COMPRESS_OVERVIEW
config option in the HFA/.img/.aux code.
Best regards,
>    gdaladdo --config use_rrd yes --config compress_overview lzw -r
> nearest 094M.tif 2 4 8 16 32
>    gdalinfo 094M.aux
> Driver: HFA/Erdas Imagine Images (.img)
> Size is 5817, 5714
> Coordinate System is `'
> Corner Coordinates:
> Upper Left  (    0.0,    0.0)
> Lower Left  (    0.0, 5714.0)
> Upper Right ( 5817.0,    0.0)
> Lower Right ( 5817.0, 5714.0)
> Center      ( 2908.5, 2857.0)
> Band 1 Block=64x64 Type=Byte, ColorInterp=Undefined
>   Description = Layer_1
>   Overviews: 2909x2857, 1455x1429, 728x715, 364x358, 182x179
>   Metadata:
>     LAYER_TYPE=athematic
>   Image Structure Metadata:
>     COMPRESSION=RLC
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
