[Gdal-dev] Converting Polar Stereographic to WGS84 long/lat
Ethan Alpert ealpert at digitalglobe.com
Wed Feb 7 14:29:54 EST 2007
I'm use GDAL 1.4.0
I thought the following gdalwarp invocation would do the trick but it
creates a black image positioned completely wrong. My file N.tif covers
the northern hemisphere. The gdalinfo is below as well as the gdalinfo
of the output file. Do I need to do something else to convert this data?
gdalwarp -t_srs "EPSG:4326"  N.tif WGS.tif
-bash-2.05b$ gdalinfo N.tif
Driver: GTiff/GeoTIFF
Size is 1024, 1024
Coordinate System is:
PROJCS["unnamed",
    GEOGCS["Coordinate System imported from GRIB file",
        DATUM["unknown",
            SPHEROID["unnamed",6367470,0]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433]],
    PROJECTION["Polar_Stereographic"],
    PARAMETER["latitude_of_origin",60],
    PARAMETER["central_meridian",-80],
    PARAMETER["scale_factor",90],
    PARAMETER["false_easting",0],
    PARAMETER["false_northing",0],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]]]
Origin = (-12184935.659713378176093,12184935.659713353961706)
Pixel Size = (23813.000000000000000,-23813.000000000000000)
Metadata:
  AREA_OR_POINT=Area
Corner Coordinates:
Upper Left  (-12184935.660,12184935.660) (145d 0'0.00"E, 20d49'33.60"S)
Lower Left  (-12184935.660,-12199576.340) (124d57'56.16"W,
20d51'29.41"S)
Upper Right (12199576.340,12184935.660) ( 54d57'56.16"E, 20d51'29.41"S)
Lower Right (12199576.340,-12199576.340) ( 35d 0'0.00"W, 20d53'25.05"S)
Center      (    7320.340,   -7320.340) ( 35d 0'0.00"W, 89d54'0.57"N
-bash-2.05b$ gdalinfo WGS.tif
Size is 2851, 157
GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.2572235629972,
            AUTHORITY["EPSG","7030"]],
        AUTHORITY["EPSG","6326"]],
    UNIT["degree",0.0174532925199433],
    AUTHORITY["EPSG","4326"]]
Origin = (-175.679918813105417,-1.452730998140064)
Pixel Size = (0.124296121889026,-0.124296121889026)
Metadata:
  AREA_OR_POINT=Area
Corner Coordinates:
Upper Left  (-175.6799188,  -1.4527310) (175d40'47.71"W,  1d27'9.83"S)
Lower Left  (-175.6799188, -20.9672221) (175d40'47.71"W, 20d58'2.00"S)
Upper Right ( 178.6883247,  -1.4527310) (178d41'17.97"E,  1d27'9.83"S)
Lower Right ( 178.6883247, -20.9672221) (178d41'17.97"E, 20d58'2.00"S)
Center      (   1.5042029, -11.2099766) (  1d30'15.13"E, 11d12'35.92"S)
Band 1 Block=2851x2 Type=Byte, ColorInterp=Gray
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070207/e7b79d49/attachment.html
