[Gdal-dev] NumPy supported in 1.4.0?
Thu Feb 8 04:45:02 EST 2007
Philip Riggs wrote:
> I understood from the news release that numpy (not Numeric) was being
> supported in 1.4.0. It looks as if only Numeric is being supported based
> on gdalnumeric.py in the Python site-packages:
> import gdal
> import _gdal
> from gdalconst import *
> from Numeric import *
>  Can somebody clear this up? Is numpy being supported now, or did I
> misunderstand the new release?
Philip,
I imagine Howard can give a fuller answer if needed, but I believe you
are still using the "old" python bindings which are I think still the
default in 1.4.0.
Try configuring --without-python --with-ngpython.  This should build
the version in gdal/swig/python which does use numpy instead of
Numeric.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
