[Gdal-dev] Re: Building against Xerces 2.7.0 fails
Benoit Myard myardbenoit at gmail.com
Fri Feb 9 09:54:12 EST 2007
Hey again.
My bad, the errors were due to GDAL. You will find two small patches
attached to this mail which correct the compilation errors.
For the sake of accuracy, GDAL 1.4.0 compiles just fine against both
Xerces 2.6.0 and 2.7.0.
See you.
Benoit Myard
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070209/3c772e00/iom_error_cpp.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070209/3c772e00/ogrili1datasource_cpp.obj
