[Gdal-dev] NumPy supported in 1.4.0?
Sat Feb 10 11:21:20 EST 2007
William Kyngesburye wrote:
> Regarding my python 2.5 const char* errors, I just got a response on the
> Mac python list.  It turns out that the Mac python build of 2.5 (unclear
> if it's mac-only, or python 2.5 in general) needs a current SWIG to
> generate gdal_wrap.cpp.  Quote:
>> This has nothing to do with numpy. The wrapper source was generated
>> from a
>> slightly-old version of SWIG that generates non-const-correct C++
>> code. Python
>> 2.5 uses a version of gcc that's a bit pickier than the 2.4 build that
>> you used.
>> Get the latest version of SWIG (1.3.31 should be fine, I think),
>> regenerate the
>> gdal_wrap.cpp, and recompile.
Howard / William,
Do you think this means we should declare 1.3.31 our new preferred version
of SWIG?  Is there any barrier (other than churn) to doing so?
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
