[Gdal-dev] ogr2ogr export from postgis to esri incorrectly exports
	attributes
    Dan Moore
    mooreds at mooreds.com
    Sat Feb 10 20:05:58 EST 2007
Hi folks,
First off, I'm pretty new to this toolset, so please forgive me if I use
incorrect terminology.
I'm using ogr2ogr to turn some data in a PostGIS database (8.1.4) into
an ESRI shapefile.  The data has about 25 fields, and when I open up the
dbf file in excel, they are exported incorrectly.  Lat/lngs are exported
correctly, but the other attributes are not.  All the values are there,
but they are offset.  Some are smashed together.  This is also apparent
when I view the exported ESRI file in QGIS (0.8).
For example, I'll have fields (| separates fields)
lat|lng|address|beds|bath|garage|heating|remarks|listprice
and the values don't align:
2.3|3.4|222 Canyon Blvd|2|2|||nice garagecentral heating||remarks...|123
Here you can see that the garage and heating sections were smashed
together, and some extra fields were put in before the garage data.
This happens after the twelfth column in the export.  The last few
fields are not in the export (they're pushed off by the blank columns).
This happens whether or not I have a where clause on this export.  I
also tried exporting a few other tables in this database, and the
attribute shifting didn't happen to either one.  Neither of those tables
had as many columns as this one, however.
Here's the output of the command when I run it with --debug on:
$ ogr2ogr --debug on -where " dataset_id = 25 " -f "ESRI Shapefile"
out.shp PG:"user=user dbname=db password=pass" data
OGR_PG: DBName="db"
OGR_PG: PostSIS version string: '1.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1'
-> '1.1'
OGR_PG: POSTGIS_VERSION=1.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
OGR_PG: Layer 'data' geometry type: POINT:Point, Dim=2
OGR_PG: Layer 'roads' geometry type: MULTILINESTRING:Multi Line String,
Dim=2
OGR: OGROpen(PG:user=user dbname=db password=pass/xxxxx) succeeded as
PostgreSQL.
OGR_PG: PQexec(DECLARE OGRPGLayerReader CURSOR for SELECT
AsEWKT("the_geom"), "address", "baths", "bedrooms", "city",
"closeddate", "construction", "contractdate", "coolsystem",
"dataset_id", "daysonmarket", "garagedesc", "heatsystem", "latitude",
"level", "listdate", "listprice", "listpriceorig", "liststatus",
"longitude", "lotsize", "mlsnumber", "offmarketdate",
"percentoflistprice", "precision", "privatepool", "remarks",
"salesprice", "schooldistrictelem", "schooldistricthigh", "schoolelem",
"schoolhigh", "schooljunior", "sqfttotal", "state", "subdivision",
"yearbuilt", "zip" FROM "data" WHERE  dataset_id = 25  )
PG: 11157 features read on layer 'data'.
However, an export to mapinfo seems to work (the attributes are all
there), and an ogr2ogr from the exported mapinfo file to an ESRI file
seems to preserve the attributes.  So I can use this workaround, but
would prefer to understand the real problem.  (As an aside, the mapinfo
export gives this error message:
ERROR 1: IMapInfoFile::CreateField() called with unsupported field type
9. Note that Mapinfo files don't support list field types.)
I googled against this list, but didn't find anything that referenced
this particular problem.
I couldn't figure out the version of ogr2ogr, but this is at the bottom
of the man page:
GDAL                       13 Apr 2006                 ogr2ogr(1)
Has anyone seen such behavior?  Can you recommend any other debugging
steps (can I turn on debugging more)?  Removing columns and seeing what
happens? Should I try to upgrade the GDAL tools?  Any other suggestions
are welcome.
Thanks,
Dan
