[Gdal-dev] NumPy supported in 1.4.0?
William Kyngesburye woklist at kyngchaos.com
Mon Feb 12 18:51:16 EST 2007
Sorry to keep replying to myself.
I just noticed that the numpy failure is for the old bindings.  The
numpy_rw_ng.py tests succeeded.
Is there a way to check for new/old bindings without failing a test?
Otherwise one gets a false sense of "something's wrong!".
On Feb 12, 2007, at 5:01 PM, William Kyngesburye wrote:
> On Feb 12, 2007, at 4:42 PM, William Kyngesburye wrote:
> Running tests from gcore/numpy_rw.py
>   TEST: numpy_rw_1 ... fail (blowup)
> Traceback (most recent call last):
>   File "pymod/gdaltest.py", line 170, in run_tests
>     result = func()
>   File "./numpy_rw.py", line 68, in numpy_rw_1
>     _gdal.GDALRegister_NUMPY()
> AttributeError: 'module' object has no attribute 'GDALRegister_NUMPY'
>   TEST: numpy_rw_2 ... skip
>   TEST: numpy_rw_cleanup ... success
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
