[Gdal-dev] Converting to GMT
Tue Feb 13 10:13:27 EST 2007
Jose Luis Gomez Dans wrote:
> Joaquim,
>>> I get the following error:
>>> gdal_translate -of GMT test.tif testOut.grd
>>> Input file size is 1347, 1032
>>> netcdf: 3 is not a valid cdfid
>> I just tried that transformation and it worked ok (1.4.0 on Win XP)
>> It only failed to convert the
>> NoData Value=-99999
>> to NaN as is expected for the default value on GMT grids
> Hmmm, it also works fine on Win2k (GDAL 1.3.1.0, FWTools 1.0.0a6, released 2005/11/03), but fails on my Linux box, and with the latest GDAL installed. i wonder why?
Jose,
I'm not sure, but I reproduced the same error message about "cdfid".  I
don't think I'll have time to build the netcdf libraries in debug and
track through to see what is happening today, so I'd appreciate it if you
could file a bug in the GDAL bugzilla about the issue.  You might note
in the bug that is also occurs "on Frank's Ubuntu system using the packaged
libnetcdf" as a reminder to me, or Mateusz.
I vaguely suspect some sort of hdf4/netcdf problems but I'm not sure.
In the meantime, it appears that the FWTools for linux build for netcdf
is working for me.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
