[Gdal-dev] Warping MODIS
Mon Feb 19 16:24:56 EST 2007
guillaume huby wrote:
> I tried (EPSG:27572 is NTF (Paris) / Lambert zone II):
> ################## Code
> gdalwarp -t_srs EPSG:27572 HDF4_EOS:EOS_GRID:"SomeData.hdf":Product:Band
> SomeData_out.tif
> gdalwarp -s_srs "+proj=sinu +lon_0=0 +x_0=0 +y_0=0 +a=6371007.181
> +b=6371007.181 +units=m  no_defs <>" -t_srs EPSG:27572
> HDF4_EOS:EOS_GRID:" SomeData.hdf":Product:Band SomeData_out.tif
> ################## End code
> These commands gave me a shift in the Y axis (around 21 km).
> Using the trick of Markus (
> http://mpa.itc.it/markus/useful/modis_hdf2erdas_ll_wgs84.sh) is a
> solution, but in 3 commands like Jose described.
> Do you know a shorter way to achieve this ?
> Thank you in advance for your reply.
Guillaume,
I have no better suggestions at this time.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
