[Gdal-dev] 100 byte shx files
Sorokine, Alexandre sorokina at ornl.gov
Tue Feb 20 15:27:50 EST 2007
All,
I was converting the projection of shapefiles from the same directoy
using the command:
ogr2ogr -t_srs proj.wkt . /media/shapefiles/
What I found is that all resulting shape files were corrupted having shx
file just 100 bytes long (basically this is a header with no content).
Convereting shapefiles one by one works fine.  Is it a bug or am I doing
something wrong?  I am using gdal gdal-1.3.2.
Alex
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070220/4776f732/attachment.html
