[Gdal-dev] 100 byte shx files
Tue Feb 20 16:46:48 EST 2007
Sorokine, Alexandre wrote:
> All,
> I was converting the projection of shapefiles from the same directoy
> using the command:
> ogr2ogr -t_srs proj.wkt . /media/shapefiles/
> What I found is that all resulting shape files were corrupted having shx
> file just 100 bytes long (basically this is a header with no content).
> Convereting shapefiles one by one works fine.  Is it a bug or am I doing
> something wrong?  I am using gdal gdal-1.3.2.
Alex,
I'm not sure why this is happening.  I would encourage you to try it also
with a recent version of ogr2ogr - perhaps from a recent FWTools build.  If
the problem still occures then you could submit a bug report with all the
details needed to reproduce it.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
