[Gdal-dev] Compile Gdal with Kakadu in sun pro forte
mbaye mbaye1234 at yahoo.fr
Wed Feb 21 03:29:17 EST 2007
I want to compile gdal with forte in solaris sunpro
when i do make i have this error
make
:allocator<char> >,VSIFilesystemHandler*> >
>::iterator,bool>__rwstd::__rb_tree<std::basic_string<char,std::char_traits<char>,std::allocator<char>
>,std::pair<const
>,VSIFilesystemHandler*>,__rwstd::__select1st<std::pair<const
>,VSIFilesystemHandler*>,std::basic_string<char,std::char_traits<char>,std::allocator<char>
>,std::less<std::basic_string<char,std::char_traits<char>,std::allocator<char>
> >,std::allocator<std::pair<const
>,VSIFilesystemHandler*> > >::insert(const std::pair<const
>,VSIFilesystemHandler*>&)
/space/export/home/mme/dev/GDAL/libgdal.a(cpl_vsil.o)
ld: fatal : Erreurs de référence aux symboles. Aucun résultat écrit dans
ogrinfo
make[1]: *** [ogrinfo] Error 1
make[1]: Leaving directory `/space/export/home/mme/dev/GDAL/ogr'
make: *** [ogr-apps] Error 2
thanks for your help
View this message in context: http://www.nabble.com/Compile-Gdal-with-Kakadu-in-sun-pro-forte-tf3265433.html#a9077068
Sent from the GDAL - Dev mailing list archive at Nabble.com.
