[Gdal-dev] RE: ogr2ogr to PostGIS gives wrong SRID?
Randy George rkgeorge at cadmaps.com
Wed Feb 21 16:43:24 EST 2007
I am attempting to use ogr2ogr to load some shp files into PostGIS
When translating a .shp file that is in EPSG:2239 and reprojecting to
EPSG:4326 like this:
ogr2ogr -f PostgreSQL PG:"user=user dbname=GA host=localhost password=pass
port=5432" 06_ZoneA.shp -s_srs EPSG:2239 -t_srs EPSG:4326 -nln test -append
The resulting table has correct coords but not a valid srid:
"SRID=32771;LINESTRING(-81.3993398544517 31.4233644295052,-81.4019931984873
31.4217494430945,-81.4036082752935 31.4205958831135,-81.4047618947201
31.4192116162976,-81.4062616063205 31.4179427019781,-81.407645959851
31.4171352080714,-81.4096071087392 31.4144 (..)"
The geometry_columns:
"";"public";"test";"wkb_geometry";"2";"32771";"LINESTRING"
The SRID constraint:
ALTER TABLE test  ADD CONSTRAINT enforce_srid_wkb_geometry CHECK
(srid(wkb_geometry) = 32771);
Adding -a_srs EPSG:4326 to the cmd line doesn't seem to change the result.
Is there another parameter required to set the SRID?
My convoluted work around:
ALTER TABLE "test" DROP CONSTRAINT enforce_srid_wkb_geometry;
UPDATE "test" SET wkb_geometry = setsrid(wkb_geometry,4326);
ALTER TABLE "test"  ADD CONSTRAINT enforce_srid_wkb_geometry CHECK
(srid(wkb_geometry) = 4326);
UPDATE "geometry_columns" SET srid=4326 WHERE f_table_name='test';
Thanks
randy
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070221/8f91777e/attachment.html
