[Gdal-dev] gdalwarp tutorial VS2003 compile error
Mateusz Loskot mateusz at loskot.net
Mon Feb 26 15:02:10 EST 2007
Huajun Zhang wrote:
> I am trying to use some code from gdal warp API tutorial, but I meet the
> compile error in VS2003:
>  error C2664: 'OGRSpatialReference::exportToWkt' : cannot convert
> parameter 1 from 'const char **__w64  ' to 'char ** '
> Do you have any idea to fix the problem?
You're probably passing const pointer where non-const is expected.
Please, show us exact code you're using, with line where you call
exportToWkt().
Cheers
Mateusz Loskot
http://mateusz.loskot.net
