[Gdal-dev] gdalwarp tutorial VS2003 compile error
Huajun Zhang huajun_zhang at usgs.gov
Mon Feb 26 15:38:58 EST 2007
 The code is as following:
    // Get Source coordinate system.
    const char *pszSrcWKT, *pszDstWKT = NULL;
    pszSrcWKT = GDALGetProjectionRef( hSrcDS );
    CPLAssert( pszSrcWKT != NULL && strlen(pszSrcWKT) > 0 );
    // Setup output coordinate system
    OGRSpatialReference oSRS;
    oSRS.SetACEA( 29.5, 45.5, 23.0, -96.0, 0.0, 0.0);
    oSRS.SetWellKnownGeogCS( "NAD83" );
    oSRS.exportToWkt( &pszDstWKT );
 Error message:  error C2664: 'OGRSpatialReference::exportToWkt' : cannot
convert parameter 1 from 'const char **__w64  ' to 'char ** '
Thanks
Huajun Zhang
Mateusz Loskot <mateusz at loskot.net>
Sent by: gdal-dev-bounces at lists.maptools.org
02/26/2007 03:02 PM
To
gdal <gdal-dev at lists.maptools.org>
cc
Subject
Re: [Gdal-dev] gdalwarp tutorial VS2003 compile error
Huajun Zhang wrote:
> I am trying to use some code from gdal warp API tutorial, but I meet the
> compile error in VS2003:
>  error C2664: 'OGRSpatialReference::exportToWkt' : cannot convert
> Do you have any idea to fix the problem?
You're probably passing const pointer where non-const is expected.
Please, show us exact code you're using, with line where you call
exportToWkt().
Cheers
Mateusz Loskot
http://mateusz.loskot.net
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070226/ec352d1d/attachment.html
