[Gdal-dev] An unsigned integer is being compared to zero.
Tue Jan 2 13:33:37 EST 2007
Martin Spott wrote:
>> cc-1020 CC: ERROR File = cpl_conv.cpp, Line = 965
>>   The identifier "atoll" is undefined.
>>       iValue = atoll( pszValue );
> Ok, apparently the 'configure' test for 'atoll' works different from
> what's expected in the source code of GDAL, the same is with
> 'copysignf' (which triggers difficulties in 'port/cpl_strtod.cpp'),
Martin,
What does "man atoll" report on your IRIX system?  The GNU C library
version is declared in stdlib.h.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
