[Gdal-dev] GDAL1.4.0RC1 test result: 'sn' is not recognized as an internal or external command
Zhonghai Wang zhonghaiw at gmail.com
Wed Jan 3 12:10:43 EST 2007
Sorry for the post, I made a mistake here. Thanks for your information,
Howard.
the answer to that is: open the command prompt from visual stiudio 2005.
Regards
Zhonghai
On 1/3/07, Zhonghai Wang <zhonghaiw at gmail.com> wrote:
> I am confused, I open the command window using the Microsoft .NET
> Framework SDK v2.0>SDK Command Prompt, surely that is under the .NET 2.0framework.
> any more suggestion?
> thanks for your answer.
> Zhonghai
>  On 1/3/07, Howard Butler <hobu at iastate.edu> wrote:
> > At 10:24 AM 1/3/2007, Zhonghai Wang wrote:
> > >Microsoft (R) Program Maintenance Utility   Version 6.00.8168.0
> > .NET requires MSVC 7.1 and above.  You are using MSVC 6.  There is no
> > .NET in 6.
> > Howard
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070103/44f1592f/attachment.html
