[Gdal-dev] Newbie queston concerning ogr2ogr for PostgreSQL
Thu Jan 4 11:13:33 EST 2007
Mateusz Loskot wrote:
> Brent Edwards wrote:
>> Why won't this work?:
>> ogr2ogr -f KML kmltest.kml "PG:dbname=postg is username=postgres
>> password=pword" -sql "SELECT * FROM district;"
> PostgreSQL driver in OGR recognizes the same connection string format as
> used by PostgreSQL API. Here is list of supported keys with explanation
> of possible values:
> http://www.postgresql.org/docs/8.1/interactive/libpq.html#LIBPQ-CONNECT
I would add that some versions of OGR do not support the default geometry
verison of some PostGIS versions.  So:
  ogr2ogr -f KML kmltest.kml "PG:..." district
might work better than an explicit SQL statement.  This issue should be
resolved with GDAL/OGR 1.4.0 (at RC1 current).
Also, you don't need to include a semi-colon in your SQL statement.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
