[Gdal-dev] Motion: Promote GDAL 1.4.0 RC1 to be GDAL 1.4.0 Final
Thu Jan 4 23:15:51 EST 2007
Tamas Szekeres wrote:
> 2007/1/4, Tamas Szekeres <szekerest at gmail.com>:
>> All of the changes I have made was reverted so GDAL 1.4.0 RC1 contains
>> the current c# version.
> I would revoke this statement because I have just fixed a problem in
> the csharp/makefile.vc
> causing that the manifest has not been embedded to
> gdal_gdalconst_wrap.dll. Without this fix using the gdalconst assembly
> module causes an application error (for the VS2005 builds). In
> addition some of the sample apps will not run.
> Is it crucial?
Tamas,
To me this doesn't sound release critical as it affects a very small subset
of GDAL users, and it is not essentially a regression since the last release
since previously the csharp stuff was unuseful.   Others may have a different
opinion.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
