[Gdal-dev] gdal_translate 1.4.0 problem
Gennady Khokhorin gok at aerometric-ak.com
Mon Jan 15 17:44:57 EST 2007
Hello.
I got a problem with gdal_translate utility. Using simplest form:
gdal_translate rgb32.tif rgb32_copyGdal.tif
produced distorted output image so some sw can not open it.
The same distorted image I got from fwTools112 (File/Export option).
Original image is 8 bits/sample, 3 samples/pixel, RGB color model, no compression.
The tiffcp 3.8.2 works fine.
Platform: winXP + msvc8.0
Test image is here: ftp://aerometric-ak:amak2014@ftp.aerometric-ak.com, go to gok/imageProcessing folder.
Could somebody help to figure out which part of translate process is wrong?
Thanks,
Gennady
