[Gdal-dev] Dataset instance has no attribute 'GetMetadataItem'
Martel, Christian Christian.Martel at drdc-rddc.gc.ca
Tue Jan 16 15:52:47 EST 2007
------This message was previously sent only to Frank (reply instead of
reply to all). My apologizes to all list members.------
Mateusz,
Frank,
Thanks for the quick answer.
I was aware of that solution. I though GetMetadataItem would be faster
because I want to extract the same metadata from hundreds of files (a
whole CIB CD).
Thanks,
Christian
> -----Original Message-----
> From: Frank Warmerdam [mailto:warmerdam at pobox.com]
> Sent: 16 janvier 2007 12:28
> To: Martel, Christian
> Cc: gdal-dev at lists.maptools.org
> Subject: Re: [Gdal-dev] Dataset instance has no attribute
> 'GetMetadataItem'
> Martel, Christian wrote:
> > Hi,
> > With fwtools 1.1.3 on XP, I wrote this python script :
> > import gdal
> > gdal.AllRegister()
> > dataset =
> gdal.Open('d:/geodata/digest/cib/cb05NJ1701_2/rpf/GJKJI22/00A56324.I22
> > ') fdt = dataset.GetMetadataItem("NITF_FDT")
> > print fdt
> > I get
> > AttributeError: Dataset instance has no attribute 'GetMetadataItem'
> > I get the same answer with a tiff file.
> > Plain GetMetadata() works great but I'd like to get specific item.
> > I found no sample python script using GetMetadataItem. How should I
> > call it ?
> Christian,
> I see that neither the old nor the new python bindings have a
> getmetadataitem operation.  You basically have to fetch all
> the metadata, and then check for the individual item.
> eg.
>    md = dataset.GetMetadata()
>    if md.has_key('NITF_FDT'):
>      print md['NITF_FDT']
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo,
> http://osgeo.org
