[Gdal-dev] GDALWarp Gif Problems
Chris Portka cportka at newwireless.com
Mon Jan 22 21:12:12 EST 2007
I can't seem to get GDAL warp to work on a gif image when converting
from one UTM zone to another.  If anyone could give me any help at all
that would be much appreciated.  I've worked on this a long time and
can't find any documentation that shows I'm doing anything incorrect.
The exception I get is in this part of the GDAL code (my code follows):
int GDALGenImgProjTransform( void *pTransformArg, int bDstToSrc,
                             int nPointCount,
                             double *padfX, double *padfY, double *padfZ,
                             int *panSuccess )
    GDALGenImgProjTransformInfo *psInfo =
        (GDALGenImgProjTransformInfo *) pTransformArg;
    int   i;
    double *padfGeoTransform;
    void *pGCPTransformArg;
    void *pRPCTransformArg;
    void *pTPSTransformArg;
    void *pGeoLocTransformArg;
    if( bDstToSrc )
        padfGeoTransform = psInfo->adfDstGeoTransform;
        pGCPTransformArg = psInfo->pDstGCPTransformArg;
        pRPCTransformArg = NULL;
        pTPSTransformArg = NULL;
        pGeoLocTransformArg = NULL;
    else
        padfGeoTransform = psInfo->adfSrcGeoTransform;
        pGCPTransformArg = psInfo->pSrcGCPTransformArg;
<-----EXCEPTION HERE
My code is very similar to the GDAL warp tutorial (the exception I get
is labeled in the middle of the code):
    GDALDriverH hDriver;
    GDALDataType eDT;
    GDALDatasetH hDstDS;
    GDALDatasetH hSrcDS;
    GDALAllRegister();
    hSrcDS = GDALOpen(fileName.toAscii(), GA_ReadOnly);
    CPLAssert(hSrcDS != NULL);
    eDT = GDALGetRasterDataType(GDALGetRasterBand(hSrcDS,1));
    hDriver = GDALGetDriverByName("GIF");
    CPLAssert(hDriver != NULL);
    char *pszSrcWKT = NULL;
    char *pszDstWKT = NULL;
    OGRSpatialReference srcSR;
    srcSR.SetUTM(18, TRUE);
    srcSR.SetWellKnownGeogCS("WGS84");
    srcSR.exportToWkt(&pszSrcWKT);
    CPLAssert(pszSrcWKT != NULL && strlen(pszSrcWKT) > 0);
    OGRSpatialReference dstSR;
    dstSR.SetUTM(17, TRUE);
    dstSR.SetWellKnownGeogCS("WGS84");
    dstSR.exportToWkt(&pszDstWKT);
    void *hTransformArg;
    hTransformArg = GDALCreateGenImgProjTransformer(hSrcDS, pszSrcWKT,
NULL, pszDstWKT, FALSE, 0, 1);
    CPLAssert(hTransformArg != NULL);
    double adfDstGeoTransform[6];
    int nPixels = 0;
    int nLines = 0;
    CPLErr eErr;
EXCEPTION HAPPENS HERE--->    eErr = GDALSuggestedWarpOutput(hSrcDS,
GDALGenImgProjTransform,
        hTransformArg, adfDstGeoTransform, &nPixels, &nLines);
    CPLAssert(eErr == CE_None);
    qDebug() << "E";
    GDALDestroyGenImgProjTransformer(hTransformArg);
    hDstDS = GDALCreate(hDriver, outputFileName.toAscii(), nPixels,
nLines, GDALGetRasterCount(hSrcDS), eDT, NULL);
    CPLAssert(hDstDS != NULL);
    GDALSetProjection(hDstDS, pszDstWKT);
    GDALSetGeoTransform(hDstDS, adfDstGeoTransform);
    GDALColorTableH hCT;
    hCT = GDALGetRasterColorTable(GDALGetRasterBand(hSrcDS, 1));
    if(hCT != NULL) {
        GDALSetRasterColorTable(GDALGetRasterBand(hDstDS, 1), hCT);
    GDALWarpOptions *warpOptions = GDALCreateWarpOptions();
    warpOptions->hSrcDS = hSrcDS;
    warpOptions->hDstDS = hDstDS;
    warpOptions->nBandCount = 1;
    warpOptions->panSrcBands = (int *) malloc(sizeof(int) *
warpOptions->nBandCount);
    warpOptions->panSrcBands[0] = 1;
    warpOptions->panDstBands = (int *) malloc(sizeof(int) *
    warpOptions->panDstBands[0] = 1;
    warpOptions->pfnProgress = GDALTermProgress;
    warpOptions->pTransformerArg =
GDALCreateGenImgProjTransformer(hSrcDS, pszSrcWKT, NULL, pszDstWKT,
FALSE, 0.0, 1);
    warpOptions->pfnTransformer = GDALGenImgProjTransform;
    GDALWarpOperation operation;
    operation.Initialize(warpOptions);
    operation.ChunkAndWarpImage(0, 0, GDALGetRasterXSize(hDstDS),
GDALGetRasterYSize(hDstDS));
    GDALDestroyGenImgProjTransformer(warpOptions->pTransformerArg);
    GDALDestroyWarpOptions(warpOptions);
    GDALClose(hSrcDS);
    GDALClose(hDstDS);
Thanks for any help you can give me,
Chris
