[Gdal-dev] --formats
Bryan Keith bryan at geomega.com
Wed Jan 24 10:47:40 EST 2007
On the subject of formats, I find it useful to use, for example:
gdalinfo --format gtiff
to get the -co options.  Is there an equivalent with ogrinfo?  Like
Bart, I'm also still running 1.3.2
Bryan
Frank Warmerdam wrote:
> Bart van den Eijnden (OSGIS) wrote:
>> Hi list,
>> using gdalinfo --formats, you get a title of the driver as well as
>> information on whether the driver is read-only, or read-write etc.
>> Using ogrinfo you don't get this information, just the driver code. It would
>> be good to synchronize the two. Especially since there are drivers which are
>> write-only in OGR.
> Bart,
> When I do "ogrinfo --formats" I get:
> warmerda at amd64[6]% ogrinfo --formats
> Supported Formats:
>    -> "ESRI Shapefile" (read/write)
>    -> "MapInfo File" (read/write)
>    -> "UK .NTF" (readonly)
>    -> "SDTS" (readonly)
>    -> "TIGER" (read/write)
>    -> "S57" (read/write)
>    -> "DGN" (read/write)
>    -> "VRT" (readonly)
>    -> "AVCBin" (readonly)
>    -> "REC" (readonly)
>    -> "Memory" (read/write)
>    -> "CSV" (read/write)
>    -> "GML" (read/write)
>    -> "KML" (read/write)
>    -> "Interlis 1" (read/write)
>    -> "Interlis 2" (read/write)
>    -> "SQLite" (read/write)
>    -> "PostgreSQL" (read/write)
>    -> "MySQL" (read/write)
> I think this was added post GDAL 1.3.2.  Was this inadequate in
> some fashion?
