[Gdal-dev] Arc-second units?
trale at centrum.cz trale at centrum.cz
Wed Jan 24 21:00:19 EST 2007
Hello,
It would appear that GDAL14 does not understand arc-second units.  I created
an elevation file (GeoTIFF) using Global Mapper.  When I look at it with
gdalinfo I get:
Driver: GTiff/GeoTIFF
Size is 777, 657
Coordinate System is:
GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.2572235630016,
            AUTHORITY["EPSG","7030"]],
        AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich",0],
    UNIT[,0.0174532925199433],
    AUTHORITY["EPSG","4326"]]
Origin = (-399424.610220731760000,116211.336444500940000)
Pixel Size = (0.647917999999991,-0.647917999999996)
Metadata:
  AREA_OR_POINT=Point
Corner Coordinates:
Upper Left  ( -399424.610,  116211.336)
(399424d36'36.79"W,116211d20'11.20"N)
Lower Left  ( -399424.610,  115785.654)
(399424d36'36.79"W,115785d39'15.55"N)
Upper Right ( -398921.178,  116211.336)
(398921d10'40.57"W,116211d20'11.20"N)
Lower Right ( -398921.178,  115785.654)
(398921d10'40.57"W,115785d39'15.55"N)
Center      ( -399172.894,  115998.495)
(399172d53'38.68"W,115998d29'43.37"N)
Band 1 Block=777x1 Type=Float32, ColorInterp=Gray
D(["mb","The UNIT is empty, but it clearly thinks the unit is DEGREES as the corner<br />coordinates are obviously completely wrong.<br /><br />When looking at the same file with a different reader (a GeoTIFF tag<br />reader), the information returned is:<br /><br />Elevation file:<br />Geotiff_Information:<br /> &amp;nbsp; &amp;nbsp;Version: 1<br /> &amp;nbsp; &amp;nbsp;Key_Revision: 1.0<br /> &amp;nbsp; &amp;nbsp;Tagged_Information:<br /> &amp;nbsp; &amp;nbsp; &amp;nbsp; ModelTiepointTag (2,3):<br /> &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp;0 &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp;0 &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp;0<br /> &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp;-399424.61 &amp;nbsp; &amp;nbsp; &amp;nbsp; 116211.336 &amp;nbsp; &amp;nbsp; &amp;nbsp; 0<br /> &amp;nbsp; &amp;nbsp; &amp;nbsp; ModelPixelScaleTag (1,3):<br /> &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp;0.647918 &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; 0.647918 &amp;nbsp; &amp;nbsp; &amp;nbsp; &amp;nbsp; 1<br /> &amp;nbsp; &amp;nbsp; &amp;nbsp; End_Of_Tags.<br /> &amp;nbsp; &amp;nbsp;Keyed_Information:<br /> &amp;nbsp; &amp;nbsp; &amp;nbsp; GTModelTypeGeoKey (Short,1): ModelTypeGeographic<br /> &amp;nbsp; &amp;nbsp; &amp;nbsp; GTRasterTypeGeoKey (Short,1): RasterPixelIsPoint<br /> &amp;nbsp; &amp;nbsp; &amp;nbsp; GeographicTypeGeoKey (Short,1): GCS_WGS_84<br /> &amp;nbsp; &amp;nbsp; &amp;nbsp; GeogAngularUnitsGeoKey (Short,1): Angular_Arc_Second<br /> &amp;nbsp; &amp;nbsp; &amp;nbsp; VerticalUnitsGeoKey (Short,1): Unknown-9001<br /> &amp;nbsp; &amp;nbsp; &amp;nbsp; End_Of_Keys.<br /> &amp;nbsp; &amp;nbsp;End_Of_Geotiff.<br /><br />The units are clearly set to Angular_Arc_Second. &amp;nbsp;If the coordinates above<br />are interpreted as arc-seconds then the corner coordinates are correct.<br /><br />First, am I understanding things correctly, and is my interpretation that<br />GDAL14 is not handling this correc
tly, correct? &amp;nbsp;Or am I missing something?<br />I\'m new to GDAL and certainly could easily be overlooking something very<br />basic.<br /><br />If GDAL does in fact not handle this type of coordinate correctly, can<br />someone point me to where in the sources I would need to make a patch? &amp;nbsp;I\'m<br />more than willing to go in and extend things as necessary.<br /><br />Thanks in advance,<br /></div>",1]
//-->The UNIT is empty, but it clearly thinks the unit is DEGREES as the corner
Elevation file:
    Version: 1
    Key_Revision: 1.0
    Tagged_Information:
          0                0                0
          -399424.61       116211.336       0
          0.647918         0.647918         1
       End_Of_Tags.
    Keyed_Information:
       End_Of_Keys.
    End_Of_Geotiff.
The units are clearly set to Angular_Arc_Second.  If the coordinates above
GDAL14 is not handling this correctly, correct?  Or am I missing something?
I'm new to GDAL and certainly could easily be overlooking something very
basic.
someone point me to where in the sources I would need to make a patch?  I'm
Thanks in advance,
Nick
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070125/f7b0aa01/attachment.html
