[Gdal-dev] ogr2ogr
Gennady Khokhorin gok at aerometric-ak.com
Wed Jan 24 22:25:09 EST 2007
Frank,
I'm debuging ogr2ogr and have couple questions about program structure.
1. Should --config "GDAL_DATA" be applyed in ogr2ogr command? If so I dont see
args handling --config in ogr2ogr.cpp. How this variable gets into the code?
2. What the story with OGR_DRIVER_PATH, GDAL_DRIVER_PATH in OGRSFDriverREgistrar::AutoLoadDrivers()?
Should I set it up at run time?
Thanks,
gennady
