[Gdal-dev] RFC 4: Geolocation Arrays
Ivan Lucena ILucena at clarku.edu
Fri Jan 26 09:33:43 EST 2007
Ok Frank,
That is good news for me in the sense that you are reformulating the RFC
4 and make the process less format/driver specific.
> So you don't really need to reassemble things into an HDF file or
> something similar.
I might try to create the HDF4 and then I use MRTSwath to project it as
long as the metadata info is OK.
Thanks,
Ivan
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Frank
Warmerdam
Sent: Thursday, January 25, 2007 8:38 PM
To: Ivan Lucena
Cc: gdal-dev
Subject: Re: [Gdal-dev] RFC 4: Geolocation Arrays
Ivan Lucena wrote:
> Hi there,
> If I understand correctly RFC 4, you can use the Geolocation bands to
> warp the image bands when they exists in the same input file (in a
> HDF-EOS Swath for example).
> This is possible only because the AVHRR, Envisat, HDF and netCDF
drivers
> have add to the Metadata the fields: "GEOLOCATION", "PIXEL_OFFSET",
> "LINE_OFFSET", "PIXEL_STEP", "LINE_STEP", "X_BAND", "Y_BAND".
Ivan,
I have some good news.  Per RFC 4 you can also have X_DATASET and
Y_DATASET metadata pointing to another file for the X and Y bands.
   http://www.gdal.org/rfc4_geolocate.html
something similar.
> But I have someone here with lots of similar kind of information but
in
> separated Envi file and he want to do the same process... :-)
> For each par of files there is one with a bunch of hyperspectral bands
> and the other with just two bands with Latitude and Longitude.
> The question is: If one invests time developing a python script to
> gather those bands in a HDF4 and set the appropriate metadata is
> gdalwarp going to work? I mean, the metadata will stick to the file
and
> will be interpreted by gdalwarp accordantly?
Unfortunately, I also have some bad news.  The gdalwarp support for
geolocation arrays does not really work.  It is basically partially
implemented but I gave up on it because I could see how to make it work
without quite a bit more work.  So, you cannot use geolocation arrays
with gdalwarp currently.
If I could get this implemented I would finalize RFC 4 and try to get it
passed, but currently I'm stymied.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush    | President OSGeo,
http://osgeo.org
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
