[Gdal-dev] gdal 1.3.2 build error
Tue Jan 30 20:16:10 EST 2007
Gong, Shawn wrote:
> Hi Frank and list,
> I downloaded gdal 1.3.2 from web and this is build error
> Note that I have copied three files (cpl_odbc.h, cpl_odbc.cpp,
> IdrisiDataset.cpp) from ___http://www.gdal.org/srctree_
> <http://www.gdal.org/srctree>
> following the lead from
> ___http://lists.umn.edu/cgi-bin/wa?A2=ind0605&L=mapserver-users&D=0&T=0&P=32523_
> <http://lists.umn.edu/cgi-bin/wa?A2=ind0605&L=mapserver-users&D=0&T=0&P=32523>
> why am I still getting idrisiDataset.cpp error?  Are there more files I
> should copy from the ___www.gdal.org/srctree_ <http://www.gdal.org/srctree>?
Shawn,
I don't think that solution applies any more since the www.gdal.org/srctree
points to the current development version and it has continued to evolve.
Is there a reason you aren't just using GDAL 1.4.0?
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
