[Gdal-dev] gdal 1.3.2 build error
Gong, Shawn Shawn.Gong at drdc-rddc.gc.ca
Wed Jan 31 13:29:54 EST 2007
Thank Frank and William for your advices.
The build on gdal 1.4 was successful.
Shawn Gong
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Tuesday, January 30, 2007 8:16 PM
To: Gong, Shawn
Cc: gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] gdal 1.3.2 build error
Gong, Shawn wrote:
> Hi Frank and list,
> I downloaded gdal 1.3.2 from web and this is build error
> Note that I have copied three files (cpl_odbc.h, cpl_odbc.cpp,
> IdrisiDataset.cpp) from ___http://www.gdal.org/srctree_
> <http://www.gdal.org/srctree>
> following the lead from
___http://lists.umn.edu/cgi-bin/wa?A2=ind0605&L=mapserver-users&D=0&T=0&
P=32523_
<http://lists.umn.edu/cgi-bin/wa?A2=ind0605&L=mapserver-users&D=0&T=0&P=
32523>
> why am I still getting idrisiDataset.cpp error?  Are there more files
I
> should copy from the ___www.gdal.org/srctree_
<http://www.gdal.org/srctree>?
Shawn,
I don't think that solution applies any more since the
points to the current development version and it has continued to
evolve.
Is there a reason you aren't just using GDAL 1.4.0?
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
and watch the world go round - Rush    | President OSGeo,
http://osgeo.org
