[Gdal-dev] support for python 2.5.1
Mon Jul 2 12:39:31 EDT 2007
John Cartwright wrote:
> Thanks Howard and Frank for your prompt replies.  I've found that
> although the compile works fine, but when I try to use the gdal python
> bindings, I get the following:
> /extra/contrib/lib/python2.5.1/site-packages/gdal.py:191:
> RuntimeWarning: Python C API version mismatch for module _gdal: This
> Python has API version 1013, module _gdal has version 1012.
>  import _gdal
> I've had the same experience on both RHEL 3, and Mac OS X 10.4.  Can you
> tell from the above what I might be doing wrong?
John,
Generally speaking this means that the gdal bindings were built against
a different version of python than you are using to load it.  Is there
any chance you have more than one python installed on these systems?
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
