[Gdal-dev] Conversion of paletted PNG to ECW does not work
Tue Jul 3 17:22:36 EDT 2007
Brent Fraser wrote:
> Frank,
>    I don't think ECW supports palettes.  As a work-around we
> can convert the files to 24-bit then ECW, so no big problem.
>     My thought was the same as the original poster's: either
> have GDAL do the 8-bit to 24-bit conversion as part of the
> format translation (for convenience and to save on temporary
> disk space), or at least produce a warning message that
> paletted files are not supported (this would save time on
> user support!)
Brent,
I agree that ECWCreateCopy() should issue a warning (or if bStrict
is TRUE an error) if a palette is present on the source image.
If you file a bug, I'll "grow the scope" a bit to cover some other
common drivers, and queue it for Mateusz to work on.  Many of the
CreateCopy() implementations are pretty quiet about the information
the ignore.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
