[Gdal-dev] PHP_OGR layer create options
Roberto Starnini roberto.starnini at gmail.com
Wed Jul 4 06:23:57 EDT 2007
I've problems setting some function parameters on ms4w php-ogr library.
There is no OGR_DS_CreateLayer() example with layer creation options and I
don't understand what kind of parameter type I have to use.
Thanks
2007/7/3, Jeff McKenna <jmckenna at dmsolutions.ca>:
> Regarding your direct email to me asking the same question as below: no
> I am no help to you regarding this.
> jeff
> Roberto Starnini wrote:
> > Hello,
> > I have used ogr/php library to migrate layers from Oracle to Postgres. I
> > have a problem with the last parameter of OGR_DS_CreateLayer()
> >  function. I have passed an array of options :
> >  $aoptions[0] = 'OVERWRITE=YES';
> >  $aoptions[1] = 'GEOMETRY_NAME=the_geom';
> > but it doesn't works.
> > Thanks for help!
> > Roberto Starnini
> Jeff McKenna
> DM Solutions Group Inc.
> http://www.dmsolutions.ca
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070704/02db70f4/attachment.html
