[Gdal-dev] memory leaks in MITAB driver
Daniel Morissette dmorissette at mapgears.com
Mon Jul 9 14:55:04 EDT 2007
Hi Richard,
I'll have a look at this when I have a minute, but to make sure it
doesn't get lost, could you please file a ticket and attach the patch?
Thanks
Daniel
Richard Matsunaga wrote:
> I've fixed a few memory leaks in the MITAB driver that have been
> plaguing me lately. Hopefully someone more qualified than I can validate
> these changes and submit them into the code base.
> Regards,
> Richard
> Index: /ogr/ogrsf_frmts/mitab/mitab_feature.cpp
> --- /ogr/ogrsf_frmts/mitab/mitab_feature.cpp (revision 11729)
> +++ /ogr/ogrsf_frmts/mitab/mitab_feature.cpp (working copy)
> @@ -7813,6 +7813,12 @@
> + if (poStyleMgr)
> +  delete poStyleMgr;
> + if (poStylePart)
> +  delete poStylePart;
>      return;
> @@ -7997,7 +8003,13 @@
>          SetBrushFGColor((GInt32)nBrushColor);
> -     return;
> + if (poStyleMgr)
> + if (poStylePart)
> +    return;
> @@ -8281,6 +8293,14 @@
>          nSymbolColor = strtol(pszSymbolColor, NULL, 16);
>          SetSymbolColor((GInt32)nSymbolColor);
> + if (poStyleMgr)
> + if (poStylePart)
>      return;
> Index: /ogr/ogrsf_frmts/mitab/mitab_imapinfofile.cpp
> --- /ogr/ogrsf_frmts/mitab/mitab_imapinfofile.cpp (revision 11728)
> +++ /ogr/ogrsf_frmts/mitab/mitab_imapinfofile.cpp (working copy)
> @@ -281,6 +281,7 @@
>      TABPoint *poTABPointFeature = NULL;
>      TABRegion *poTABRegionFeature = NULL;
>      TABPolyline *poTABPolylineFeature = NULL;
> + const char *styleString = NULL;
>       * MITAB won't accept new features unless they are in a type derived
> @@ -300,11 +301,11 @@
>        case wkbPoint:
>          poTABFeature = new TABPoint(poFeature->GetDefnRef());
> -        if(poFeature->GetStyleString())
> +  styleString = poFeature->GetStyleString();
> +        if(styleString)
>              poTABPointFeature = (TABPoint*)poTABFeature;
> -            poTABPointFeature->SetSymbolFromStyleString(
> -                poFeature->GetStyleString());
> +            poTABPointFeature->SetSymbolFromStyleString(styleString);
>          break;
> @@ -313,14 +314,13 @@
>        case wkbPolygon:
>        case wkbMultiPolygon:
>          poTABFeature = new TABRegion(poFeature->GetDefnRef());
> +        if(styleString)
>              poTABRegionFeature = (TABRegion*)poTABFeature;
> -            poTABRegionFeature->SetPenFromStyleString(
> +            poTABRegionFeature->SetPenFromStyleString(styleString);
> -            poTABRegionFeature->SetBrushFromStyleString(
> +            poTABRegionFeature->SetBrushFromStyleString(styleString);
>          break;
> @@ -329,11 +329,11 @@
>        case wkbLineString:
>        case wkbMultiLineString:
>          poTABFeature = new TABPolyline(poFeature->GetDefnRef());
> +        if(styleString)
>              poTABPolylineFeature = (TABPolyline*)poTABFeature;
> -            poTABPolylineFeature->SetPenFromStyleString(
> +            poTABPolylineFeature->SetPenFromStyleString(styleString);
>          break;
> @@ -381,6 +381,8 @@
>          eErr = OGRERR_FAILURE;
>      delete poTABFeature;
> + if (styleString != NULL)
> +  CPLFree((void *)styleString);
>      return eErr;
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
Daniel Morissette
http://www.mapgears.com/
