[Gdal-dev] gdal_translate Basic Usage / UTM to latlong
Tim Osborn tosborn at sbcglobal.net
Wed Jul 11 22:08:32 EDT 2007
You indicate that the provider says the image is projected in UTM NAD83.
EPSG:2860 that you specified is a State Plane Coordinate System projection
for the Central Zone of Wisconsin.
However, the coordinates output by gdalinfo don't look like UTM
coordinates....they look more like State Plane Coordinates in meters.
However, the lat long coordinates you say you expect for the center of the
map would be located in the Wisconsin South State Plane Coordinate Zone.  So
I would try EPSG:32154 which is NAD83 Wisconsin South Zone SPC, meter.
View this message in context: http://www.nabble.com/gdal_translate-Basic-Usage---UTM-to-latlong-tf4065198.html#a11552519
Sent from the GDAL - Dev mailing list archive at Nabble.com.
