[Gdal-dev] Will increasing the RAM on a server increase the speed of gdalwarp?
Ed McNierney ed at topozone.com
Fri Jul 13 14:20:26 EDT 2007
John -
It will almost certainly increase the speed.  That¹s not at all the same as
saying that it is worth it, or that the speed increase will be significant.
Your disks are the slowest part of the process.  Please describe in detail
both the input and the output disk subsystems you are using for your
gdalwarp process.  Then we can see if that¹s the first place to look.
     - Ed
Ed McNierney
Chief Mapmaker
Demand Media / TopoZone.com
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
Phone: (978) 251-4242
Fax: (978) 251-1396
ed at topozone.com
Date: Fri, 13 Jul 2007 14:00:05 -0400
To: Gdal-Dev <gdal-dev at lists.maptools.org>
Cc: <mitchelljj98 at gmail.com>, Mark A Hollis <mahollis at insequenceinc.com>,
<smithpack at gmail.com>
Subject: [Gdal-dev] Will increasing the RAM on a server increase the speed
of gdalwarp?
If I have a server that currently has 4 gigs of RAM and I increase the RAM
to say 75 gigs will I notice a difference in the speed of processing a 75
gig image via gdalwarp?
Thanks,
John J. Mitchell
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070713/00a19a78/attachment.html
