[Gdal-dev] Possible enhanced NetCDF support in GDAL
A.Th.C. Hulst hulst at argoss.nl
Mon Jul 16 02:24:27 EDT 2007
Hi Paavo,
sorry I didn't respond earlier, but I had a small vacation.
On Friday 06 July 2007 04:47:12 Paavo.Jumppanen at csiro.au wrote:
> By those conventions this driver will pick identlen as X and time as Y!
> Clearly, I won't get a meaningful map out of it with the standard
> driver.
I can't see why. This is per variable base and it states that time goes before
level and level before y and x. Your data (and virtually all modelled data)
follows that convention. One of my variablesis:
short meridional_wind_speed(time, latitude, longitude) ;
and that shows perfectly in mapserver (in grayscale). It should also work for
your sea surface temperature.
Sander
