[Gdal-dev] What are georeferenced coordinates?
Ethan Alpert ealpert at digitalglobe.com
Thu Jul 19 17:06:02 EDT 2007
The output of gdalinfo on your source image file as well as your command
line invocation of gdal_translate would be useful in determining your
problem.
-e
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Kent
Eschenberg
Sent: Thursday, July 19, 2007 2:52 PM
To: GDAL
Subject: [Gdal-dev] What are georeferenced coordinates?
What are georeferenced coordinates? I can't find a definition in any of
the
GDAL documents. I would guess they are longitude and latitude.
I'm trying to use the "-projwin" option for gdal_translate with valid
longitude
and latitude. But this always fails saying they are outside the bounds
of the
input image. "-srcwin" works as expected.
"gdal_translate --version" yields "GDAL 1.4.2.0, released 2007/06/27".
I'm
using a Redhat Fedora Core 5 system.
TIA!
Kent
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
