[Gdal-dev] Possible enhanced NetCDF support in GDAL
A.Th.C. Hulst hulst at argoss.nl
Fri Jul 20 11:43:31 EDT 2007
On Friday 20 July 2007 02:23:35 Paavo.Jumppanen at csiro.au wrote:
> Looks good!
> I note from your map file there are 3 PROCESSING LUT entries, for each
> band I presume? With 3 bands map server assumes RGB representation
> doesn't it?
Yes.
> Whilst this looks easy enough to use, creating colour maps
> based on RGB representation isn't great. Hue, lightness and saturation
> representation would be far better (which is what I use in my driver).
I never worked with HSV before. The processing option also accepts a file for
each band. Can't you translate a HSV colormap to RGB and feed that to
mapserver?
> What does MapServer return when you do a spatial query on a point on
> your map? One thing my version of MapServer doesn't do correctly is
> include the scaling in the query return. It just returns the unscaled
> value.
You mean as in: the scale and offset is properly applied? I haven't tried but
I guess is that this is al right because the min/max values returned by
gdalinfo are correct.
Regards,
Sander
