[Gdal-dev] Proposed Feature: Consumption of URL-based Spatial References
Jan Hartmann j.l.h.hartmann at uva.nl
Tue Jul 24 07:04:19 EDT 2007
Yes, this is a good idea. I am working with historical maps with their
own projections (e.g. central meridian in Paris), and a central
repository for those definitions would be very welcome. One wish: it
would be nice to be able to name the projections, e.g. "Cassini" for the
18th century French projection. Did you know BTW that our definition of
the meter as 1/40000 of the globe circumference comes from work done for
creating that projection?
Jan
Dr. J. Hartmann
Department of Geography
University of Amsterdam
Howard Butler wrote:
> All,
> Chris Schmidt and I have been working on a website
> <http://spatialreference.org> that reflects the EPSG spatial reference
> codes database and user-contributed codes in a variety of output
> formats.  The EPSG code database is never as up to date as you would
> like, and we frequently tell people to hack their /usr/share/proj/epsg
> database file with made up codes to support alternative projections.  If
> we could consume URL-based spatial references with OSR, all that would
> be required is someone adds the custom coordinate system definition to
> the site and then everyone could refer to it at that location (hopefully
> indefinitely).
> As for the website itself, if it has uptake and people find it useful,
> we will work to put it somewhere it can live for a very long time -- for
> example OSGeo.  The source code (it's written in Django) will be made
> available so anyone can stand up their own version of the site.
> I would like to propose that an ImportFromUrl() method be added to
> OSRSpatialReference that constructs a spatial reference given the
> SetFromUserInput data retrieved at the given URL.  It would only need to
> be as specific as that, and it wouldn't need to refer to
> spatialreference.org.  Additionally, this mechanism could be used to
> support GML SRS retrieval from URLs (which Frank mentioned was in the
> spec) in the future.  This method would only be active if you have
> included curl support, of course.  Maybe someday, if necessary, we do
> some magical caching, but that'd be a premature optimization at this point.
> Here's an example:
> ogr2ogr -a_srs http://spatialreference.org/epsg/4326/proj4 -t_srs
> http://spatialreference.org/user/6/proj4 world_borders.shp
> world_borders_google.shp
> Howard
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
