[Gdal-dev] Measured Values for Shapefile read & write
Nelson, Dean dean.nelson at eecradar.com
Tue Jul 24 12:34:57 EDT 2007
Craig,
Would this be like a projected shape file (i.e. x,y off of a median) ?
Regards,
Dean Nelson
Enterprise Electronics Corp
	-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Craig Hunter
	Sent: Tuesday, July 24, 2007 11:25 AM
	To: gdal-dev at lists.maptools.org
	Subject: [Gdal-dev] Measured Values for Shapefile read & write
	I performed a hack to the OGR source in order to read and write
shapefiles with measured values.  If others may find this of value, I'll
work on a patch?
	Also, the SDE driver only provides read access.  Is there some
technical or proprietary issues with performing write access to SDE? or
has this not been developed due to a lack of interest?
	Thanks,
	Craig Hunter.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070724/47239a5b/attachment.html
