[Gdal-dev] Measured Values for Shapefile read & write
Craig Hunter craigrthunter at gmail.com
Tue Jul 24 13:52:26 EDT 2007
Dean,
Are you referring to an offset, in the sense you have a point on a line and
you want to project it 100 meters off to the left side (90 degrees) of the
line?  In that case, *no*, but I'm pretty sure that can already be performed
with the ogr library as it is now.
I'm referring to measured values (M-values) that are included in the
geometry and can be used for dynamic segmentation.
(Sorry for the repeated message, I left the mailing list off my initial
reply)
On 7/24/07, Nelson, Dean <dean.nelson at eecradar.com> wrote:
>  Craig,
> Would this be like a projected shape file (i.e. x,y off of a median) ?
> Regards,
> Dean Nelson
> Enterprise Electronics Corp
>  -----Original Message-----
> *From:* gdal-dev-bounces at lists.maptools.org [mailto:
> gdal-dev-bounces at lists.maptools.org] *On Behalf Of *Craig Hunter
> *Sent:* Tuesday, July 24, 2007 11:25 AM
> *To:* gdal-dev at lists.maptools.org
> *Subject:* [Gdal-dev] Measured Values for Shapefile read & write
> Hi,
> I performed a hack to the OGR source in order to read and write shapefiles
> with measured values.  If others may find this of value, I'll work on a
> patch?
> Also, the SDE driver only provides read access.  Is there some technical
> or proprietary issues with performing write access to SDE? or has this not
> been developed due to a lack of interest?
> Thanks,
> Craig Hunter.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070724/15ca8115/attachment.html
