[Gdal-dev] Measured Values for Shapefile read & write
Nelson, Dean dean.nelson at eecradar.com
Tue Jul 24 15:32:33 EDT 2007
Yes, I was projecting to a WSG84 from a Lambert_Azimuthal_Equal_Area
projection (as far as I can tell) See the "[Gdal-dev] Is ogr2ogr the
tool to use?" thread.
Regards,
Dean Nelson
Enterprise Electronics Corp
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Dylan
Beaudette
Sent: Tuesday, July 24, 2007 1:53 PM
To: gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] Measured Values for Shapefile read & write
Sounds like there was some kind of NADGRID mixup.... ? where you
projecting
across datums?
cheers,
Dylan
On Tuesday 24 July 2007 11:34, Nelson, Dean wrote:
> Craig,
> We would like our product to ingest any type of shape file (projected
> or
> lat/lon) and be able to run with it. However, as in the "[Gdal-dev] Is
> ogr2ogr the tool to use?" thread, I have some shapefile data from the
> USGS/Hydro1k project that is projected from a point and all of the
> values in the polygons are x,y values. I needed to convert to a
Lat/Lon
> shapefile. I did it via ogr2ogr and the resulting output was placed
17km
> north of reality.
> I was looking for a kludgy fudge factor ;-)
> Regards,
> Dean Nelson
> 	From: Craig Hunter [mailto:craigrthunter at gmail.com]
> 	Sent: Tuesday, July 24, 2007 12:52 PM
> 	To: Nelson, Dean
> 	Cc: gdal-dev at lists.maptools.org
write
> 	Dean,
> 	Are you referring to an offset, in the sense you have a point on
> a line and you want to project it 100 meters off to the left side (90
> degrees) of the line?  In that case, no, but I'm pretty sure that can
> already be performed with the ogr library as it is now.
> 	I'm referring to measured values (M-values) that are included in
> the geometry and can be used for dynamic segmentation.
> 	(Sorry for the repeated message, I left the mailing list off my
> initial reply)
> 	On 7/24/07, Nelson, Dean <dean.nelson at eecradar.com> wrote:
> 		Craig,
> 		Would this be like a projected shape file (i.e. x,y off
> of a median) ?
> 		Regards,
> 		Dean Nelson
> 			From: gdal-dev-bounces at lists.maptools.org
> [mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Craig Hunter
> 			Sent: Tuesday, July 24, 2007 11:25 AM
> 			Subject: [Gdal-dev] Measured Values for
> 			Hi,
> 			I performed a hack to the OGR source in order to
> read and write shapefiles with measured values.  If others may find
this
> of value, I'll work on a patch?
> 			Also, the SDE driver only provides read access.
> Is there some technical or proprietary issues with performing write
> access to SDE? or has this not been developed due to a lack of
interest?
> 			Thanks,
> 			Craig Hunter.
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
