[Gdal-dev] How to correct use GDALGCPTransform
Ivan Mjartan ivan.mjartan at geovap.cz
Wed Jul 25 03:30:53 EDT 2007
Hi list,
So I have scan of raster without georeference and I need make geo
position of this raster into SJTSK coordinate (*EPSG:102067*). I need do it
on the fly. So I am trying use GDALCreateGCPTransformer.
My input is raster it can be tiff, bitmap, jpg and so on . output can be
Geotiff
In my test I use polynomial order 1 and 3 GCPs points.
I followed tutorial on GDAL page. But I am not success I am doing something
wrong and I not able find right way.
In the beginning I created blank dataset to get GeoTransform and output size
of image like in gedalwarp.exe it is correct and I get black Geotiff and
coordinate and size is correct. (The same when I use gedal_translate.exe to
set GCPs and than gdalwarp to warp image). But when try use
ChunkAndWarpImage with same Transformer the output image is still blank.  So
I also tried debug this method and I find that inside this method is used
WarpRegion Method but there was wrong parameters of destination image. So I
try use WarpRegion directly without success L
I thing that I am wrong using GCPTransformer I thing that I have to set
something in GDALWarpOptions but what? This is for me big mystery. I was
looking on internet but there is nothing L
Can I see some sample of using GCPTransformer ?
May be I can use GenImgProjTransformer but I don't know how to set GCPs with
out prior transform to Gtiff set GCPs and saving to Disk. (Input rasters can
be jpg bitmap .)
So like input I used this image http://80.188.225.114/temp/input.tif
I am using GDAL 1.4.2
Thanks a lot for your help
Ivan Mjartan
the code looks like follow:
Method to get destination dataset
GDALDatasetH GDALWarpCreateOutput( char *papszSrcFiles,char *pszFilename,
                      const char *pszFormat,GDAL_GCP pasGCPList[3],int
nReqOrder,int bReversed,int nGCPCount)
    GDALDriverH hDriver;
    GDALDatasetH hDstDS;
    void *hTransformArg;
    GDALColorTableH hCT = NULL;
    int nDstBandCount = 0;
                        GDALDataType eDT;
                        int nOrder = 1;
                        hDriver = GDALGetDriverByName( pszFormat );
        GDALDatasetH hSrcDS;
        hSrcDS = GDALOpen( papszSrcFiles, GA_ReadOnly );
                        if( hSrcDS == NULL )
            exit( 1 );
        eDT = GDALGetRasterDataType(GDALGetRasterBand(hSrcDS,1));
        nDstBandCount = GDALGetRasterCount(hSrcDS);
        hCT = GDALGetRasterColorTable( GDALGetRasterBand(hSrcDS,1) );
                        if( hCT != NULL )
            hCT = GDALCloneColorTable( hCT );
                        hTransformArg = GDALCreateGCPTransformer (
                                   nGCPCount,
                                   pasGCPList,
                                   nReqOrder,
                                   bReversed
        if( hTransformArg == NULL )
            return NULL;
        double adfThisGeoTransform[6];
        int    nThisPixels, nThisLines;
                        CPLErr eErr;
        eErr = GDALSuggestedWarpOutput( hSrcDS,GDALGCPTransform,
hTransformArg,adfThisGeoTransform,&nThisPixels, &nThisLines);
                        /*if (eErr == CE_None)
            return NULL;
                        GDALDestroyGCPTransformer(hTransformArg);
                        GDALClose( hSrcDS );
                        hDstDS = GDALCreate( hDriver, pszFilename,
nThisPixels, nThisLines,
                         nDstBandCount, eDT, NULL);
                        if( hDstDS == NULL )
                                   return NULL;
                        GDALSetProjection( hDstDS, "");
                        GDALSetGeoTransform( hDstDS, adfThisGeoTransform );
                        if( hCT != NULL )
                                   GDALSetRasterColorTable(
GDALGetRasterBand(hDstDS,1), hCT );
                                   GDALDestroyColorTable( hCT );
                        return hDstDS;
and my main method looks:
int main( int argc, char ** argv )
    const char         *pszFormat = "GTiff";
            int i;
    GDALDataType        eOutputType = GDT_Unknown, eWorkingType =
GDT_Unknown;
    GDALResampleAlg     eResampleAlg = GRA_NearestNeighbour;
            char               **papszWarpOptions = NULL;
            //moje definice
            char *pszSrcFilename = NULL;
            char *pszDstFilename = NULL;
            GDAL_GCP pasGCPList[3];
            int nReqOrder = 1;
            int bReversed = 0;
            int nGCPCount = 3;
/*      input and output rasters                         */
            //pszSrcFilename =
CPLStrdup("c:\\Projects\\GDAL\\gdal142\\gedalwarp\\gedalwarp\\Debug\\out_beroGCP.tif");
            //pszSrcFilename =
CPLStrdup("c:\\Projects\\GDAL\\gdal142\\gedalwarp\\gedalwarp\\Debug\\21.tif");
            pszSrcFilename =
            pszDstFilename =
CPLStrdup("c:\\Projects\\GDAL\\gdal142\\gedalwarp\\gedalwarp\\Debug\\out_r.tif");
    GDALAllRegister();
            //gcplist
            pasGCPList[0].dfGCPPixel = 0;
            pasGCPList[0].dfGCPLine = 0;
            pasGCPList[0].dfGCPX = -863909;
            pasGCPList[0].dfGCPY = -993283;
            pasGCPList[0].dfGCPZ = 0;
            pasGCPList[0].pszId = "1";
            pasGCPList[0].pszInfo = "info 1";
            pasGCPList[1].dfGCPPixel = 0;
            pasGCPList[1].dfGCPLine = 3403;
            pasGCPList[1].dfGCPX = -863909;
            pasGCPList[1].dfGCPY = -1024899;
            pasGCPList[1].dfGCPZ = 0;
            pasGCPList[1].pszId = "2";
            pasGCPList[1].pszInfo = "info 2";
            pasGCPList[2].dfGCPPixel = 3800;
            pasGCPList[2].dfGCPLine = 3403;
            pasGCPList[2].dfGCPX = -809988;
            pasGCPList[2].dfGCPY = -1024899;
            pasGCPList[2].dfGCPZ = 0;
            pasGCPList[2].pszId = "3";
            pasGCPList[2].pszInfo = "info 3";
            hDstDS = GDALWarpCreateOutput( pszSrcFilename,
pszDstFilename,pszFormat,pasGCPList,nReqOrder,bReversed,nGCPCount);
        exit( 1 );
    hSrcDS = GDALOpen(pszSrcFilename, GA_ReadOnly );
         exit( 2 );
/*      Create a transformation object                                */
                                   nGCPCount,
                                   pasGCPList,
                                   nReqOrder,
                                   bReversed
            return NULL;
/*      Setup warp options.                                             */
        GDALWarpOptions *psWO = GDALCreateWarpOptions();
                        psWO->pfnProgress = GDALTermProgress;
                        psWO->eWorkingDataType =
        //psWO->eResampleAlg = eResampleAlg;
        psWO->hSrcDS = hSrcDS;
        psWO->hDstDS = hDstDS;
        psWO->pfnTransformer = GDALGCPTransform;
        psWO->pTransformerArg = hTransformArg;
/*      Setup band mapping.                                             */
                        psWO->nBandCount = GDALGetRasterCount(hSrcDS);
        psWO->panSrcBands = (int *) CPLMalloc(psWO->nBandCount*sizeof(int));
        psWO->panDstBands = (int *) CPLMalloc(psWO->nBandCount*sizeof(int));
        for( i = 0; i < psWO->nBandCount; i++ )
            psWO->panSrcBands[i] = i+1;
            psWO->panDstBands[i] = i+1;
/*      Initialize and execute the warp.                                */
        GDALWarpOperation oWO;
        if( oWO.Initialize( psWO ) == CE_None )
                                   //if (oWO.ChunkAndWarpImage( 0, 0,
GDALGetRasterXSize( hDstDS ),GDALGetRasterYSize( hDstDS ) )==CE_Failure){
                                               //printf("Error");
                                   oWO.WarpRegion( 0, 0,
GDALGetRasterXSize( hDstDS ),GDALGetRasterYSize( hDstDS ),0, 0,
GDALGetRasterXSize( hSrcDS ),GDALGetRasterYSize( hSrcDS ));
/*      Cleanup                                                         */
                        if( hTransformArg != NULL ){
hTransformArg );
                        GDALClose( hDstDS );
        GDALDestroyWarpOptions( psWO );
                        GDALDestroyDriverManager();
    return 0;
