[Gdal-dev] Re: trouble with "gdal_translate-a_nodata" for Erdas Imagine output
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Wed Jul 25 04:16:04 EDT 2007
Mark Phillips <mbp <at> geomtech.com> writes:
> Hi.  I'm using FWTools-1.3.4 on Linux, and I'm having trouble adding a
> NoData file to an Erdas Imagine file with gdal_translate.  It works
> fine for GeoTiff.  Am I doing something wrong?  Does Erdas Imagine
> support NoData values?  Here's a session showing what I'm doing:
Hi.
I made a trial with gdalwarp, which gave me a message:
ERROR 6: SetNoDataValue() not supported for this dataset.
I don't know if it is because of Imagine .img format or the driver, but
obviously NoData value can not be set.
-Jukka Rahkonen-
