[Gdal-dev] Reproject with Mapserver vs gdalwarp
Wed Jul 25 09:27:45 EDT 2007
José Vicente Higón wrote:
> In both cases I was using the latest FWTools release (1.3.4)
> Why Did I get differents results in MApserver and gdalwarp?Any clue?
José,
GDAL does not generally use the PROJ.4 epsg init file.  Instead it has
a set of .csv files with the EPSG definition information.
I think you will want to edit this line of FWTools/data/pcs.csv:
23030,"ED50 / UTM zone
30N",9001,4230,16030,9807,1,0,8805,0.9996,9201,8802,-3,9102,8801,0,9102,8807,0,9001,8806,500000,9001,,,,,,
To include include the TOWGS84 values.  Something like:
30N",9001,4230,16030,9807,1,0,8805,0.9996,9201,8802,-3,9102,8801,0,9102,8807,0,9001,8806,500000,9001,-87,-98,-121,0,0,0,0
You might want to verify that GDAL is picking up the definition properly
by entering "testepsg EPSG:23030" in the FWTools shell which will
report the coordinate system in various forms.  Make sure that one (the
first I think) includes the proper TOWGS84[] parameters and that they make
it into the final PROJ.4 rendering.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
