[Gdal-dev] Measured Values for Shapefile read & write
Norman Vine nhv at cape.com
Thu Jul 26 10:33:43 EDT 2007
Nelson, Dean writes:
> I have tried the solution suggested by Frank with no change in the
> results. However, in delving deeper into the data for this particular
> project, it appears that all of this data is off about 10 min
> in Lat. I
> can't explain it - so I'll ask the source: USGS - which may
> prove to be
> a daunting task for a whimp like me.
Is there a web link to the data you are using  ??
The USGS is usually very good about providing sufficient metadata
It usually just requires a little poking around on the site to find
Cheers
Norman
