[Gdal-dev] gdalinfo on large file...
Christopher Condit condit at sdsc.edu
Sun Jul 29 14:17:14 EDT 2007
I've got a fairly large (3.7GB) GMT/GMT NetCDF Grid file. If I run
gdalinfo without -mm it seems fine. However, when I ask for -mm I see a
series of these error in the console (the Y offset varies):
ERROR 1: GMT scanline fetch failed: Invalid argument
ERROR 1: IReadBlock failed at X offset 0, Y offset 21599
and the resulting min/max is incorrect. Is there something special I
need to do to get gdalinfo to work with such a large file?
Thanks,
-Chris
