[Gdal-dev] OGR_csharp sample code
Mateusz Loskot mateusz at loskot.net
Fri Jun 1 10:00:22 EDT 2007
Folks,
FYI, if you like, you can add interesting snippets to the GDAL Wiki:
http://trac.osgeo.org/gdal/wiki/CodeSnippets
Mateusz
Milo van der Linden wrote:
> Hello,
> I have added some of the source I am using in VB.net to do exactly as
> what you are requesting. There are a couple of things you have to keep
> in mind:
> - Build enumerators that mimic the enumerators that are in the original
> OGR dll's
> - Be careful, base for featurecount are different for shape files or
> mapinfo tab (the first starts at 0, the other at 1)
> Let me be honest, I am not giving you the code in detail. Google Earth
> content is core business for my own little company (3DSite,
> http://www.3dsite.nl)
> I have spent a lot of time getting it to what it is now, I am not
> working for a boss beside this and nobody is funding my effort. Maybe
> you can give me some insight on what you are going to use it for?
> Perhaps we can partner in the business, Greece is not to far away from
> the Netherlands and I am a great fan of Greece!
> First, at the loading of my vb.net application I register all OGR file
> types:
>  'Register all filetypes for use with OGR
>         OGR.ogr.RegisterAll()
> I have a Class that holds the following objects:
> Datasets Collection of type Dataset (selfmade class)
> Dataset looks something like this:
> Public Class Dataset
>         Private _DataSource As OGR.DataSource
>         Private _Driver As OGR.Driver
>         Private _Name As String
>         Private _Path As String
>         Private _Extension As String
>         Private _FileName As String
>         Private _Layers As Layers
>         Private _NameField As String
>         Private _GroupField As String
>         Private _SortField As String
> where I turn all these private variables into public properties
> Then I have 2 constructors in the dataset object:
>         Public Sub New(ByVal name As String, ByVal path As String, ByVal
> extension As String)
>             _Name = name
>             _Path = path
>             _Extension = extension
>             _FileName = _Path & "\" & _Name & _Extension
>             _DataSource = OGR.ogr.Open(_FileName, 0)
>             _Driver = _DataSource.GetDriver()
>         End Sub
>         Public Sub New(ByVal FileName As String)
>             Dim j As Integer
>             _Layers = New Layers
>             _FileName = FileName
>             _Path = System.IO.Path.GetDirectoryName(FileName)
>             _Extension = System.IO.Path.GetExtension(FileName)
>             _Name = System.IO.Path.GetFileNameWithoutExtension(FileName)
>             For j = 0 To _DataSource.GetLayerCount - 1
>                 Dim lyr As New Layer(_DataSource.GetLayerByIndex(j))
>                 _Layers.Add(lyr)
>             Next
>         End Sub
> The Layer object is an enhanced version of the OGR.Layer object:
> Public Class Layer
>         Private _fieldtable As DataTable = New DataTable("Fields")
>         Private _sr As New OGR.SpatialReference("")
>         Private _ogrLayer As OGR.Layer
>         Private _name As String
>         Private _def As OGR.FeatureDefn
>         Private _FeatureCount As Integer
>         Private _Type As Integer
> The Layer Object also has an advanced constructor:
> Public Sub New(ByVal lyr As OGR.Layer)
>             ' Create DataColumns and set various properties.
>             Dim fName As DataColumn = New DataColumn
>             fName.DataType = System.Type.GetType("System.String")
>             fName.AllowDBNull = True
>             fName.Caption = "Name"
>             fName.ColumnName = "name"
>             fName.DefaultValue = ""
>             ' Add the column to the table.
>             _fieldtable.Columns.Add(fName)
>             Dim fNum As DataColumn = New DataColumn
>             fNum.DataType = System.Type.GetType("System.String")
>             fNum.AllowDBNull = True
>             fNum.Caption = "Type"
>             fNum.ColumnName = "type"
>             fNum.DefaultValue = 0
>             _fieldtable.Columns.Add(fNum)
>             Dim tmp As String = ""
>             _ogrLayer = lyr
>             _def = _ogrLayer.GetLayerDefn()
>             _name = _def.GetName
>             _FeatureCount = _ogrLayer.GetFeatureCount(1)
>             _Type = _def.GetGeomType
>             Dim i As Integer
>             For i = 0 To _def.GetFieldCount() - 1
>                 Dim row As DataRow
>                 row = _fieldtable.NewRow()
>                 Dim FieldDef As OGR.FieldDefn = _def.GetFieldDefn(i)
>                 row("name") = FieldDef.GetName
>                 row("type") = FieldDef.GetFieldType
>                 _fieldtable.Rows.Add(row)
>             Next
>             _sr = _ogrLayer.GetSpatialRef
>             _sr.ExportToProj4(tmp)
>             If tmp = "" Then
>                 Dim ATproj4 As String = "+proj=tmerc +lat_0=12.51697
> +lon_0=-69.994775 +k=0.9996 +x_0=10000 +y_0=15000 +towgs84=0,0,0,0,0,0,0
> +units=m +no_defs"
>                 '    'Pop up a dialog stating that the source projection
> is invalid!
>                 '    '"No Source coordinate system defined, proceed?"
>                 _sr.ImportFromProj4(ATproj4)
>             Else
>                 Debug.Print("Source coordinate system: " & tmp)
>             End If
>         End Sub
> Then, for the conversion to KML, I loop through this Dataset-Layer object
> Dim lyr As ClassData.Layer
>             For Each lyr In _ds.Layers
>                 count = lyr.Count
>                  For j = i To count
>                     Dim feat As OGR.Feature = lyr.Feature(j)
>                     If Not feat Is Nothing Then
>                         Dim geom As OGR.Geometry = feat.GetGeometryRef
>                         If Not geom Is Nothing Then
>                             Dim geomType As wkbGeometryType
>                             geomType = geom.GetGeometryType
>                             If geomType = wkbGeometryType.wkbLineString
> Or geomType = wkbGeometryType.wkbPolygon Or geomType =
> wkbGeometryType.wkbPoint Or geomType = wkbGeometryType.wkbMultiPolygon Then
>                                 ..... Now you have reached the point
> where you have a valid object!, use it to convert to a kml string
>             Next
> IMPORTANT:
> If you are using non US system settings: You can use this code to make
> sure comma's are interpreted correctly:
> Sub DoTheThing
>     'First, store the CurrentCulture so it can be reset after the
> routine is done
>             Dim originalCulture As System.Globalization.CultureInfo
>             originalCulture = CultureInfo.CurrentCulture
>             'Google Earth needs the locale to be set to US so the . and
> , are interpreted correctly
>             Thread.CurrentThread.CurrentCulture = New
> CultureInfo("en-US", True)
>                 DoTheConversionHere
>             'Reset the CurrentCulture
>             Thread.CurrentThread.CurrentCulture = originalCulture
> end sub
> Kind regards,
> Milo van der Linden
> 3DSite - Milo van der Linden - CTO
> Groenedijk 12, 4441 TJ  Ovezande (Zeeland, Nederland)
> milo at 3dsite.nl <mailto:milo at 3dsite.nl>
> <skype:milovanderlinden?chat>
> De informatie verzonden met dit e-mail bericht is uitsluitend bestemd
> voor de geadresseerde(n). Gebruik van deze informatie door andere dan de
> geadresseerde(n) is verboden. Openbaarmaking, vermenigvuldiging,
> verspreiding en/of verstrekking van deze informatie aan derde is niet
> toegestaan. Kopiëren en/of misbruiken van ingesloten afbeeldingen en/of
> bestanden is wettelijke verboden en strafbaar. 3DSite staat niet in voor
> de juiste en volledige overbrenging van de inhoud van een verzonden
> e-mail, noch voor tijdig ontvangst daarvan. Op al onze leveringen,
> aanbiedingen en verkopen zijn van toepassing onze Algemene Voorwaarden,
> zoals gedeponeerd bij de K.v.K. te Middelburg. 3DSite
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
Mateusz Loskot
http://mateusz.loskot.net
