[Gdal-dev] Can GDAL GDALDataset return compressed image data
Lucena, Ivan ivan.lucena at pmldnet.com
Fri Jun 8 20:01:13 EDT 2007
Alison,
Anyone, Correct me If I am wrong but I don't think that in the GDAL API
there is a function that delivers the haw compressed data block in a
buffer. But if you look at that piece of code:
http://trac.osgeo.org/gdal/browser/trunk/gdal/frmts/nitf/nitfdataset.cpp#L908
That is where the NITF JPEG buffer is passed to the GDAL JPEG driver to
be decoded. Then, take a look at the code at:
http://trac.osgeo.org/gdal/browser/trunk/gdal/frmts/jpeg/jpgdataset.cpp#L1099
And line 1274 where generic JPEG tables are loaded to make it look like
a JFIF file so that the libjpeg can decode it.
Regards,
Ivan
Alison Luo wrote:
> I have my own JPEG and JP2K decoder. I do not need
> decompressed image data stream acquired from
> GDALDataset::RasterIO. I would simply like to get the
> JPEG or JP2K compressed image stream from a NITF file
> through GDAL. Can this be accomplished?
> Thanks,
> Alison
> ____________________________________________________________________________________
> Building a website is a piece of cake. Yahoo! Small Business gives you all the tools to get online.
> http://smallbusiness.yahoo.com/webhosting
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
